Front-End Loader FEL mounted post hole digger
/ FEL mounted post hole digger #1
bandit67
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
I'm not able to narrow down the search enough, so I'll ask in a new thread.
I'm looking for companies that sell hydraulic post hole diggers that can attach to the front end loader. Not too keen on the ones that bolt onto the side of the bucket, so I want one that can hook up to a QA. It'll be for a compact size machine up to 30hp +/-.
Thanks in advance.
/ FEL mounted post hole digger #2
Maybe check out Worksaver. They have several types of hydraulic units from the simple "strap on" type to the quick attach type.
Thanks for the link.
/ FEL mounted post hole digger #6
The downside to a quick attach PHD on a CUT, is the auger is in the middle of a skid steer type quick attach PHD. You can't see the tip of the auger because of the tractor and it is difficult to place tip precisely without the aid of someone else. I have a Bobcat model 15 PHD on my JD 3720 and live with that limitation but still much easier to use than rear PHD. The bit spins a little slow because of the flow rate, but the torque is there since the pressure is about the same. I did turn my JD hydraulic pressure up to near 2800 psi. Bobcat's run at 3000 psi. All the major skid steer companies probably have a hydraulic PHD. Many other aftermarket companies also available
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2021 Kubota BX2680 25HP 4WD Utility Loader Tractor w/ Attachments and 2021 T/A Flatbed Trailer (A66734)
2021 Kubota BX2680...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
CAT 320EL Hydraulic Thumb (A68134)
CAT 320EL...
