Front-End Loader FEL mounted post hole digger
/ FEL mounted post hole digger #1
bandit67
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
I'm not able to narrow down the search enough, so I'll ask in a new thread.
I'm looking for companies that sell hydraulic post hole diggers that can attach to the front end loader. Not too keen on the ones that bolt onto the side of the bucket, so I want one that can hook up to a QA. It'll be for a compact size machine up to 30hp +/-.
Thanks in advance.
/ FEL mounted post hole digger #2
Maybe check out Worksaver. They have several types of hydraulic units from the simple "strap on" type to the quick attach type.
Thanks for the link.
/ FEL mounted post hole digger #6
The downside to a quick attach PHD on a CUT, is the auger is in the middle of a skid steer type quick attach PHD. You can't see the tip of the auger because of the tractor and it is difficult to place tip precisely without the aid of someone else. I have a Bobcat model 15 PHD on my JD 3720 and live with that limitation but still much easier to use than rear PHD. The bit spins a little slow because of the flow rate, but the torque is there since the pressure is about the same. I did turn my JD hydraulic pressure up to near 2800 psi. Bobcat's run at 3000 psi. All the major skid steer companies probably have a hydraulic PHD. Many other aftermarket companies also available
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2007 Chevrolet Silverado 1500 Pickup Truck (A64194)
2007 Chevrolet...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2022 EZ-GO ELITE...
(4) 25' Texas Built Stand Alone Livestock Panels (A66408)
(4) 25' Texas...
Minneapolis-Moline U Tractor (A66285)
Minneapolis-Moline...
