FEL lift very slow.
/ FEL lift very slow. #1
Andyfr
Scottish Highlands, UK
Kubota B2150HSDB 4WD
Hi
The FEL on my B2150 has gradually got slower and slower. All the other operations are fine it's just the lift. The only way I can get it to lift at the correct speed is to stand up and put all my weight on the lever. I assume that there is a problem with the valve, is it something I can do myself or will I have to take it to a specialist?
/ FEL lift very slow. #2
I had same problem with my hoe. curl only was slow.
the nut came off the bolt that ataches the lever to the conrol valve for the curl. And bolt was halfway out. It took 10mins to put bolt in and nut back on. So i'd take cover off for valve access and see if same thing happened on you're FEl valve.
Hi Bob
Thanks for the reply. I can see the lever and the piston which goes into the valve and there are no loose nuts. I'm pretty sure the problem is inside the valve, although I'm only guessing. If I put normal pressure on the lever it will go up really slow and as I apply more pressure it gets quicker. When I put all my weight on the lever then it operates at the correct speed.
Someone suggested that it could be the spool valve seals. Is this a possiblity and would I be able to replace them myself?
Thanks in advance. /forums/images/graemlins/smile.gif
/ FEL lift very slow. #5
Yes, you shouldn't have any problem replacing the seals.
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
Dodge Charger (A56859)
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
LOOK! (A63109)
LOOK! (A63109)
