Loader FEL level indicator rod.
   / FEL level indicator rod. #41
Seems simple enough. I even looked for levels with digital remotes. I feel like this should be easily found, or easily made.
   / FEL level indicator rod. #42
Wax man made one for his Kubota. The thread is about two months ago
   / FEL level indicator rod. #43
Couldn't find the thread, so I msg'd him. If I get a response, I'll put the info/link here.
   / FEL level indicator rod. #45
The guy does awesome work.
Still, he is using the rod. I'd like this to be fully electronic.
   / FEL level indicator rod. #46
Design one, and if it is not too expensive, I expect people would be interested in buying it.. I was able to straighten my pretzled up rod. It happened on mine in the first few hours of use. I put it in a thread here. It was because the rod holder loosened up. I fixed the damage and made sure it would never happen again with locktight and stippling of the threads. The rod is made of good quality steel and can be rebent back straight with some judicious work.
James K0UA
   / FEL level indicator rod. #47
James K0UA
James, mine came loose on my new DK50 within the first 30 minutes of use. Luckily, I noticed it before pretzeling it. Put some blue loctite on the threads and tightened it up and it has stayed so far. Thought about using red loctite but decided against it.
   / FEL level indicator rod. #48
I was working at night and did not see it until I parked it
   / FEL level indicator rod. #49
WaxMan's setup ain't right...... Guys that do that precise of design and build should not be allowed to post. ;););)
Very, very, very cool. :thumbsup:
Yanmar YT359 (A53317)
2002 International 9200i Truck (A55315)
2002 International...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
Adams 6Ton Hydraulic Lime Spreader (A55315)
Adams 6Ton...
