FEL Joystick problem
/ FEL Joystick problem #1
fireman649
Port St. Lucie, Florida
Kubota B7100HST Diesel 4x4
Hi, I have a 1993 B7100 HST with a Kubota FEL(not sur of number) The joystick works fine raising and lowering, but when you curl the bucket either way, the stick will not center on it's own. Broken spring??? What do yall think. Any help would be greatly appreciated..
/ FEL Joystick problem #2
Operator error? Leave a Fireman locked in a room with two bowling balls, come back an hour later and one will be missing and the other broken.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
A local 43 brother....
/ FEL Joystick problem #3
If it doesn't have ice in the backend of the spool, I would say to first check to make sure everything is lined up. If it has been bent even a little, it would be too much for that linkage. Second, lube it up good with some spray grease.
/ FEL Joystick problem #4
On my B7100 I was starting to have problems controlling the the bucket. Replacement of the joystick linkages fixed all the problems.
Egon /forums/images/graemlins/grin.gif
HAHA thats funny, I don't care who you are!!!
Theres no ice in it, I'm in Florida.
Thanks for the posts
/ FEL Joystick problem #6
Sorry I couldn't give anything useful, but I saw your screenname and couldn't help myself... Hope you get it fixed...
/ FEL Joystick problem #7
Hiya Steve, how goes it?
Here's a link Lost Float Position On B7510 that might help. (I know it's not your same exact problem, but it might shed some light on the subject).
The poster was having a problem with the detent mechanism itself (pictures are included), but Egon is probably on to something regarding messed up linkages. There might be some springs in there somewhere too - dunno, I've never really studied mine.
And hats off to you, Ryan and all you other brave men and women who keep us all safe. I have the utmost respect for firefighters, EMT's and police officers, and I actually envy you for the tremendous "job satisfaction" that you must all have.
And Ryan, I have to disagree with you about the bowling balls. I don't see how a firefighter could actually lose one. /forums/images/graemlins/laugh.gif
oh, we could lose them......
Thanks for the nice words, we all appreciate it.
I'll check into that other post, Thanks
/ FEL Joystick problem #9
John,
Thanks for the support, our support has always been good, but of course the 343 brother we lost in 9-11 really made people take notice.
As for losing the ball, easily done, not as easy as breaking the other though.... /forums/images/graemlins/grin.gif
Hi all,
Just wanted to post an update to my problem. I took the covers off on the end of the pistons, looked goo, little water in the big one, but not the one that was affected. Regreassed the springs, and put back together, still not working right. I took the linkage apart, and greased all the moving points, and bored out where the big anchor goes into the body, it works great, just to much rust in that area.
Thanks for all the posts...
/ FEL Joystick problem #11
I offered a remedy in another thread a while ago. This is what we do with our hydraulics on our roll off trailers and have done on my ag equipment.
Takle the covers off the end of the actuation end (where the cable or linkage actuates the internal pistons or valves) and, drill a small hole so the water/condensation can drain out. Obviously, the hole has to face downward. 1\64" is plenty. Clean the innards, liberally grease everything with a good grade synthetic grease like Lubriplate and button it up. Even if you don't actually spray water on the valve body, the heating and cooling from use will cause internal condensation and corrosion.
/ FEL Joystick problem #12
Mine was sure grungy and rusty inside. Looked like rusty, crunchy mayonaise in there. Carb cleaner, hole on bottom, compressed air and new lube (spray lithium) cleared the problem up right quick.
/ FEL Joystick problem #13
<font color="blue"> Mine was sure grungy and rusty inside. Looked like rusty, crunchy mayonaise in there. </font>
Sounds just like my belly-button. Maybe I'll try the carb-clean and compressed air - thanks! /forums/images/graemlins/laugh.gif
/ FEL Joystick problem #14
Mike:
Nuthi'n like a satisfied customer.
For the life of me, I can't figure out why a small drain hole isn't in every actuator body other than planned obsolence.
My roll-off trailer got so bad I broke the handlever right off and the company had to get another one.
/ FEL Joystick problem #15
You are right. Dealer told me that years ago, Kubota started putting holes in there, then quit for some reason. Now, some are coming thru with holes again. Seems like some new bean counter comes along every once in a while and says "why are we doing that?? Extra cost! Stop it and we'll save money!" No one remembers what the hole was for, so they quit putting it in there till problems occur, and another engineer says "you know, if we put a little hole there, this wouldn't happen". Here we go again.
Brake Drums (A62613)
FORREST CITY 2R BED SHAPER & CONDITIONER (A63291)
FORREST CITY 2R...
JOHN DEERE 2950 TRACTOR (A63291)
JOHN DEERE 2950...
MINI FLAT BOTTOM GRAPPLE (A61572)
MINI FLAT BOTTOM...
WHITE 2-60 TRACTOR (A63291)
WHITE 2-60 TRACTOR...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
