FEL Joystick Issue
/ FEL Joystick Issue #1
jbunkley
North Florida
2006 Branson 3510i
With the tractor running & joystick in neutral and trying to raise/lower & dump/curl the bucket, the stick is hard to move in either direction. Can't finesse it anymore. Not sure I even know how to explain it.
Let's say I have something on the forks and I want gently raise or lower it to a certain height, the joystick is hard to maneuver & when it finally does, it either throws the forks too high or too low.
Hope I explained it well enough.
2007 3510i
Could someone explain what's happening?
Thanks
/ FEL Joystick Issue #2
Have you lubricated all the linkages the connect the lever to the valve?
Yes I have. It's like it locks in the neutral position.
Thanks for the reply.
/ FEL Joystick Issue #4
Reconnect the QD's if you have them. Put a gage in the system and monitor pressure.
/ FEL Joystick Issue #5
Mine does this in the winter, but thats because water gets in the cable and freezes. I doubt thats whats happening to you. It could be corrosion from trapped water in the cable thats making it difficult to operate the stick.
/ FEL Joystick Issue #6
Motorcycle shops (well, the ones that STILL serve bikes without shaft drives - a dying breed, fortunately) have cable lubers for cheap.
Small aerosol (I know, the environment) can with a straw that connects to a fitting that goes around the bare inner wire - you can figure the rest.
If you have trouble getting the cable free just use the can and straw, aim it as best you can.
/ FEL Joystick Issue #7
There SHOULD BE an intermediate position where the flow is very low, as in "Finesse".
A small aerosol (I know, the environment) can with a straw that connects to a fitting that goes around the bare inner wire - you can figure the rest.
If you have trouble getting the cable out, just use the can and straw.
Aim it as best you can.
/ FEL Joystick Issue #8
If there are cables between the joystick and the valves that'll most likely be where the problem is.
If you can get a bit of lubricant into the cable that might loosen it up, but it may also mean water and dust are in there too.
/ FEL Joystick Issue #9
2007 3510i
Thanks
You do not have cable controls, so it is not that. Pull back the rubber boot where your joystick enters the valve. See if anything is loose or broke in there. For a while, they used a cheesy potmetal "L" shaped bracket that would break. They are now made of steel and last a lifetime. Generally it is one of these two things, both are an easy fix.
