FEL hydraulics - hard hydraulic line replacement
/ FEL hydraulics - hard hydraulic line replacement #1
Mike52
Glen Mills, PA
Massey Ferguson 220 Compact Diesel
I have an MF 220 with a small Massey loader. The hard hydraulic lines on it are pretty rusted, and dinged up. Anyone know of a firm that can sell me replacements or build new ones? Or, am I better off getting the tubing bender out and making a set myself?
/ FEL hydraulics - hard hydraulic line replacement #2
Any local hydraulic shop can make new ones for you, probably less expensively than purchasing new ones from MF. You will need more than a tubing bender to make the proper end fittings. Check the local Yellow Pages for your nearest hydraulic shop.
/ FEL hydraulics - hard hydraulic line replacement #3
Or if you want to get rid of the steel hard lines altogether you can just fab up some replacement flexible hydraulic lines yourself using the replaceable type end fitting's.
Personally I would get new steel lines made up. They last ALOT longer and are much more damage resistant. Like stated previously, check the yellow pages for a local hydraulic shop.
/ FEL hydraulics - hard hydraulic line replacement #4
Take your old lines to NAPA. they can make up new stainless lines with flared fittings.
/ FEL hydraulics - hard hydraulic line replacement #5
you do relize that new hardlines are considered to be plantum plated when it comes to cost right?!?!
thanks gents....I'm off to NAPA
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
UNUSED FUTURE DM39-39" HYD DISC MULCHER (A60432)
UNUSED FUTURE...
Toro (A56857)
Toro (A56857)
John Deere 6110M (A53317)
John Deere 6110M...
2022 KOMATSU WA500-8 WHEEL LOADER (A60429)
2022 KOMATSU...
