Loader FEL hydraulic problem
   / FEL hydraulic problem #1
ksterling
My fel functions properly for awhile (10 minutes) then it loses the ability to raise the front of the tractor off the ground. It will still lift and dump, but will not lift the tractor. Any ideas?
   / FEL hydraulic problem #2
Will it lift a full bucket or just raise and lower an empty bucket?
First thought is that once the system gets warm you have leak path greater than pump flow reducing the pressure you can build. If you have the equipment or can get the equipment install a pressure gauge in the pressure line to your FEL. When system is cold run a function until it dead heads and see what the pressure is. Now warm the system up and at a similar RPM operate the same function until it dead heads and compare the two pressures. If very little difference with that function try raising the front of the tractor off the ground and see what the pressure reads. If it won't build pressure now or it builds less pressure I would suspect bad seals on your lift cylinders.
If there is a significant difference in pressure from step 1 you will have go farther into diagnostics. Next test will be to time the bucket raise with load from ground level to full height at a given engine RPM cold and hot. If these times are significantly different that would be an indication that you are loosing flow from the pump and it could be a relief valve stuck partially open or your pump starting to die. To do further diagnostics would require a flow meter, relief valve, etc. to isolate components one at a time to find the failing item.
What model and vintage of tractor is this?
   / FEL hydraulic problem #3
yep.. need more info on this to help you.
   / FEL hydraulic problem #4
what grade of oil are you using ? a thin oil will work well until it gets hot ... then it slips past the pump gears ( just creating heat instead of useful work ) and limits your max pressure .... an oil that is too thick will not flow at low temps ( until it warms up ) did the problem just come all of a sudden? or slowly get worse ?
   / FEL hydraulic problem #5
Perhaps you are using regen mode which will provide less power.
On some tractors, regen is in the first part of lever movement, and others tractors the regen is to the far right past a soft stop.
Install a hyd gage in the hyd system and use it to monitor and trouble shoot the hyd system.
   / FEL hydraulic problem #6
there could be a few probs going on.your loader hoses are loosing their connection to the remotes.2 you could be using the wrong hydro oil.3 your hydro filter could be stopped up.4 the hydro flow valve couldve gotten messed with if you have 1.
   / FEL hydraulic problem #7
Make sure you 3 point hitch lever is neutral, if its open it will draw pressure from the loader, check the simple things 1st and be sure all your levers are closed. It's real easy to snag them getting on and off the tractor or simply holding on during heavy work
   / FEL hydraulic problem #8
Install a hyd gage and test the pressure to see if the pump is working normal.
   / FEL hydraulic problem #9
Check the control stick linkages for sloppiness and wear.:D
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
Sedan (A59231)
Sedan (A59231)
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
