FEL homebuilt on current model Simplicity Conquest
   / FEL homebuilt on current model Simplicity Conquest #1
gaspumpgary
Queensbury,New York
Simplicity Conquest 23 hp
Hi guys as promised but delayed a few more shots of my homebuilt loader. First kudos to Paul at P F Engineering I purchased the basic plans from him last fall worth every penny it was my first hydraulic project and had a bunch of dumb questions I probably contacted him 4 or 5 times over length of build he was always very helpful After reviewing plans soon realized it wouldn't be a walk in the park I didn't wanta cut up the Sim wanted it to have a "bolt on factory look" So I decided that my vertical towers would be angled backward to pick up body lines on the hood Well that was like going from round wheels to square wheels (almost) Anyway it did really mess up all the hydr ram travel and geometry struggled for several days with thin aluminum strips that where drilled with holes to represent the rams at rest and at extended. Being a machinist with my own well equipped shop I added a few nicer touches I radius milled lots of the parts including the pivoting ends of the lifting arms they are also reamed, fitted with flanged oil lite bushings and assembled with shoulder bolts had originally planned to go with a 44" wide bucket but after urging by my welder friend "uncle dick" it stayed 4 feet wide local fab shop bent the bucket shell for me (90$) labor ...it was my metal I welded everything myself except the bucket side panels and heli arcing the NPT ports on the tower Other friend "doctor joe" helped a great deal with cutting and drilling the steel then mockup and repeated assembly and
disassembly As steel work started to come together my wife remarked that Simplicity orange was nearly the same color as Phillips 66 orange
So guess what its Phillips orange so everything was torn apart one last time some recycled steel was sandblasted welds where ground and all steel was degreased throughly we had a very mild thanksgiving 2011 and I was lucky enough to paint in late Nov 2 coats epoxy primer and 3 coats of acrylic enamel a few days after paint drying dr joe, joes dad Allen and I reassembled things fit up nicely
A old hi school friend Paul and I did all the hose and hydraulic assembly in a day and half
Paul from PF eng. furnished us with a check list to do the hydraulic fluid "injection" we only lost about 1/4 qt of ATF
The owners manual of my old AC 616 says machine weights approx. 1000 # at rear axle so that photo kinda shows the FEL capacity
So I think saying it will lift 500 lb. is quite realistic
Its been a real workhorse look at the battle scars on the bucket I don't baby it We only had 1 serious snowstorm last winter
but it was a very heavy slushy mess I bought a set of chains at TSC tractor was awesome I was lifting very very watery snow
building snowbanks approaching 5 feet tall
Have had several minor problems would notice a wandering front wheel a small hand file and new spindle snap ring fixed that in 20 min
and broke the rod end on the tractors power steering ram another easy quick fitted!
Hey my daughter is ready to load photos so more later thats light years past me
thanks Gary
goggle PF Eng plans to get info on diy tractor FEL and bucket loaders Paul in Amherst ,Mass
I just rec my micro backhoe plans for the old AC616
   / FEL homebuilt on current model Simplicity Conquest #2
Impressive!! :)
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2012 International Prostar (A56438)
2012 International...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
Batco 35' PTO Driven Belt Auger (A59814)
Batco 35' PTO...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
