FEL HELP/BENT FRAME?
/ FEL HELP/BENT FRAME? #1
Bart
I have an AG TECH Quick Tach FEL on my 1710 4wd Ford
The left side of the bucket seems higher than the right side,when the bucket sits on level ground about 2 inches.Will this be a pain to fix ? The left cylinder does not seem to retract as far as the right cylinder . The frame doesn't really look bent though,any suggestions
/ FEL HELP/BENT FRAME? #2
Before you do anything check the air in your tires mainly your rears and make sure the pressure is the same. This problem came up a while ago and thats all it was.
/ FEL HELP/BENT FRAME? #3
Bart, it does sound like something is bent. Either the uprights on the tractor, the loader arms or the "torque tube" that connects the two arms. Good news is it probably isn't a big deal. A decent body/frame shop could probably take some measurements, figure out what's bent and straighten it though if it were me I'd just get used to it as is /w3tcompact/icons/smile.gif
Been told to try to bend it back by hooking on a tree or something ....I think I'll wait a bit before i do that
/ FEL HELP/BENT FRAME? #5
Had a similiar problem but was higher on the left side. Frame was not bent but the FEL subframe was loose and the right side was hanging down /w3tcompact/icons/shocked.gif. Bought the new bolts to replace those that were gone and the loader is straight again.
Don't expect this would be your issue since "the cylinder on the left does not seem to retract as far" but thought it would be worth while tossing out as an easy item to check.
/ FEL HELP/BENT FRAME? #6
I'm not familiar with this brand but, if it is the style that to remove it you have to loosen a nut on each side and let the flap drop, then it just may have been put on on unlevel ground. I would first detach it and reattach it before doing anything drastic.
Yea it is the type with a nut on it,and it recently was removed while they painted it.Thanks for the great suggestion
2021 John Deere Gator TX4x2 Turf Utility Cart (A64194)
2021 John Deere...
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
International Harvester (IH) 130 Manure Spreader (A66408)
International...
2022 EZ-GO ELITE...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
