FEL hardline repair
   / FEL hardline repair #1
jpinca
South San Francisco Bay, CA
JD 2000 4300 HST 4WD
I have a hole in my 420 FEL's hardline (P/N AW29322)
Anyone know if this is a standard size (say 3/8" tube) that I cold just splice with autoshop brake line and two fittings?
   / FEL hardline repair #2
braze it...
   / FEL hardline repair #3
I would not recommend trying to repair the tube with a splice. You would be better off replacing it.
   / FEL hardline repair #4
Where on the line is it leaking? Could mke a difference on the repair.
Buying a piece of the "Proper Tubing" and then bending it should not break the bank. :)
If there is a rub spot make sure and ortect the tubing.:)
   / FEL hardline repair #5
If there is a rub spot make sure and protect the tubing.:)
   / FEL hardline repair #7
I agree to braze the line if break isn't at fitting/flare
   / FEL hardline repair #8
yep.. we got plenty of jd and cat industrial equipment with lon hard lines that run the length of the machine that get a poke hole now and then.. drain, clean em up and run some brass around it and go...
Two of mine (curl/dump) were pretty mangled and one finally got a pin hole. Demolition work is hard on the loader hydraulics....
I played around with splicing new segments of tube in, but the flaring was a PITA with my cheap kit.
Since the replacement lines are only $100,each I just ordered two and should have them by the weekend.
If the lines were otherwise in good shape, I'd seriously consider brazing.
And yes, these were 3/8" or at least the 3/8" tube tubes fit correctly. The JD lines seemed to have thicker walls.
   / FEL hardline repair #10
I recall once seeing the PSI's on a brazed joint and was surprised that it was up there in chrome molly (4130) ranges.
So, brazing is the way to go.
2018 ASV Posi-Track RT120F (A47477)
2018 ASV...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
BUYERS PREMIUM & PAYMENT TERMS (A54607)
BUYERS PREMIUM &...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
