FEL hardline repair
   / FEL hardline repair #1
jpinca
South San Francisco Bay, CA
JD 2000 4300 HST 4WD
I have a hole in my 420 FEL's hardline (P/N AW29322)
Anyone know if this is a standard size (say 3/8" tube) that I cold just splice with autoshop brake line and two fittings?
   / FEL hardline repair #2
braze it...
   / FEL hardline repair #3
I would not recommend trying to repair the tube with a splice. You would be better off replacing it.
   / FEL hardline repair #4
Where on the line is it leaking? Could mke a difference on the repair.
Buying a piece of the "Proper Tubing" and then bending it should not break the bank. :)
If there is a rub spot make sure and ortect the tubing.:)
   / FEL hardline repair #5
If there is a rub spot make sure and protect the tubing.:)
   / FEL hardline repair #7
I agree to braze the line if break isn't at fitting/flare
   / FEL hardline repair #8
yep.. we got plenty of jd and cat industrial equipment with lon hard lines that run the length of the machine that get a poke hole now and then.. drain, clean em up and run some brass around it and go...
Two of mine (curl/dump) were pretty mangled and one finally got a pin hole. Demolition work is hard on the loader hydraulics....
I played around with splicing new segments of tube in, but the flaring was a PITA with my cheap kit.
Since the replacement lines are only $100,each I just ordered two and should have them by the weekend.
If the lines were otherwise in good shape, I'd seriously consider brazing.
And yes, these were 3/8" or at least the 3/8" tube tubes fit correctly. The JD lines seemed to have thicker walls.
   / FEL hardline repair #10
I recall once seeing the PSI's on a brazed joint and was surprised that it was up there in chrome molly (4130) ranges.
So, brazing is the way to go.
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2018 JLG G9-43A (A47477)
2018 JLG G9-43A...
2015 CHEVROLET C3500 SERVICE TRUCK (A51406)
2015 CHEVROLET...
2018 Yamaha 48 Volt Drive 2 Golf Cart (A52377)
2018 Yamaha 48...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
