FEL hardline repair
   / FEL hardline repair #1
jpinca
South San Francisco Bay, CA
JD 2000 4300 HST 4WD
I have a hole in my 420 FEL's hardline (P/N AW29322)
Anyone know if this is a standard size (say 3/8" tube) that I cold just splice with autoshop brake line and two fittings?
   / FEL hardline repair #2
braze it...
   / FEL hardline repair #3
I would not recommend trying to repair the tube with a splice. You would be better off replacing it.
   / FEL hardline repair #4
Where on the line is it leaking? Could mke a difference on the repair.
Buying a piece of the "Proper Tubing" and then bending it should not break the bank. :)
If there is a rub spot make sure and ortect the tubing.:)
   / FEL hardline repair #5
If there is a rub spot make sure and protect the tubing.:)
   / FEL hardline repair #7
I agree to braze the line if break isn't at fitting/flare
   / FEL hardline repair #8
yep.. we got plenty of jd and cat industrial equipment with lon hard lines that run the length of the machine that get a poke hole now and then.. drain, clean em up and run some brass around it and go...
Two of mine (curl/dump) were pretty mangled and one finally got a pin hole. Demolition work is hard on the loader hydraulics....
I played around with splicing new segments of tube in, but the flaring was a PITA with my cheap kit.
Since the replacement lines are only $100,each I just ordered two and should have them by the weekend.
If the lines were otherwise in good shape, I'd seriously consider brazing.
And yes, these were 3/8" or at least the 3/8" tube tubes fit correctly. The JD lines seemed to have thicker walls.
   / FEL hardline repair #10
I recall once seeing the PSI's on a brazed joint and was surprised that it was up there in chrome molly (4130) ranges.
So, brazing is the way to go.
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED TRAILER (A54607)
2025 GREAT DANE...
2009 Ford F750 Reel Loader Truck (A52377)
2009 Ford F750...
2003 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2003 CATERPILLAR...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
