FEl Grease Zerks
   / FEl Grease Zerks #11
Where did you buy your grease gun and the moly grease? Who has the best prices? /w3tcompact/icons/smile.gif
   / FEl Grease Zerks #12
My loader manual says to use a high quality grease designating "extreme pressure"
Should I not use Walmart grease?
-T
   / FEl Grease Zerks #13
My opinion is that there are probably only a few manufacturers of all of the brands out there. I would guess that WalMart uses one of the major oil companies to supply the grease with the WalMart label on it.
My best guess would be that as long as the specifications are the same there would be no problem. I think that the main thing is the frequency of the greasing. By putting in new grease you drive out the metal dirt and moisture that has accumulated in the bearing areas.
I personally grease untill I see the grease come out without any discoloration, then I opperate the FEL and give each zerk another couple of shots. It is also a good idea to wipe the zerks off before greasing so that no dirt gets pushed into the area that you are greasing.
Just my opinion though,
Don
   / FEl Grease Zerks #14
I purchased a couple tubes of extreme pressure grease from Pep Boys. I purchased a new grease gun from nothern tool. (It was cheaper than pep boys even with shipping.)
2025 SDLANCH TRAILED CRUSHER (A58216)
2025 SDLANCH...
20FT X 12FT LIVESTOCK METAL SHED (A58216)
20FT X 12FT...
SKID STEER ATTACHMENT PACKER (A58216)
SKID STEER...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
Mini Excavator (A55787)
Mini Excavator...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
