FEL FLOAT
   / FEL FLOAT #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I was planning to do some bushhogging and hoped to use the technique described by others here of leading with the bucket slightly curled in float position. Not sure I have float pos on new TC40DA
   / FEL FLOAT #2
With the bucket flat on the ground, move your joystick rapidly to its maximum forward position. If the front wheels pop off the ground, you don't have float. If the bucket just sits there, you do have float.;)
   / FEL FLOAT
10-4 J-man. Thanks much. I'll give it a try next weekend when I have a date with machine.
   / FEL FLOAT #4
What is the bushoggin method using the float capability of the FEL?
Thanks Rick T.
   / FEL FLOAT #5
I must respectfully disagree...Try practicing first with the bucket about a foot off the ground to you get used to "popping" it into float or you will be doing wheelies:D
   / FEL FLOAT #6
I have never used it in float position before but I always keep the bucket close enough to the ground to catch stumps or rocks you can't see,if you hit something the tractor just stops so you can backup and go around it or check to see what it is then raise the mower. MH
   / FEL FLOAT #7
You are spoilin' all the fun. Not only will you go up fast, but when it goes all the way into float, you come down fast too.:eek:
You are absolutely correct, if you start a foot off the ground, you will not look like a low rider doing a hydraulics test.:rolleyes:
   / FEL FLOAT #8
flINTLOCK,
I run mine with the bucket 6" to a foot off the ground with the bucket curled sometimes, but rarely in float position. If you have the bucket floating on the ground you will have to lift it at every turn or else you could catch something and twist the loader frame while turning.
   / FEL FLOAT #9
Ford850 said:
flINTLOCK,
Agreed. Not only that, but pushing the bucket in float position puts a lot of stress on the loader frame. Float position is great for backing up and dragging light dirt, but pushing should be done seldom and with caution.
   / FEL FLOAT
OK guys, looks like the nays have it for floating the FEL to scout for obstacles during bush hoggin'. Thanks
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
(1) VISSANI REFRIGERATOR (A51248)
(1) VISSANI...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
2022 COSEN INTERNATIONAL INC V-1822 BAND SAW (A51248)
2022 COSEN...
