flINTLOCK said:I was planning to do some bushhogging and hoped to use the technique described by others here of leading with the bucket slightly curled in float position. Not sure I have float pos on new TC40DA
jinman said:With the bucket flat on the ground, move your joystick rapidly to its maximum forward position. If the front wheels pop off the ground, you don't have float. If the bucket just sits there, you do have float.![]()
kennyd said:I must respectfully disagree...Try practicing first with the bucket about a foot off the ground to you get used to "popping" it into float or you will be doing wheelies![]()
Ford850 said:flINTLOCK,
I run mine with the bucket 6" to a foot off the ground with the bucket curled sometimes, but rarely in float position. If you have the bucket floating on the ground you will have to lift it at every turn or else you could catch something and twist the loader frame while turning.
