FEL float position stuck.
/ FEL float position stuck. #1
wedge40
Not sure if this should be here or in the hydraulics section. I read on TBN about the float position and decided to see if I had one and if so try it out. Well I do have one and it seems to work pretty good. Too good because now it's stuck in the float position. I can raise and lower the FEL like normal but now I can't get any down pressure to apply. It will only do float. I'm guessing something got stuck when I used it. Any suggestion as how to fix this? I'm not keen on taking the valve off, but if that's the only way I will.
In case you're wondering it's a Koyker 210 loader, thats about 5 years old.
Wedge
/ FEL float position stuck. #2
Sounds like your linkage is dry and stuck, you need to lube the balls in the detent cap.
FEL float UN-STUCK. :D Once in float mode I have to wait a while when just using down pressure for it to go back to normal.
Wedge
3-Pt Disk (A66285)
3-Pt Disk (A66285)
2017 WEILER P265 ASPHALT PAVER (A65053)
2017 WEILER P265...
Vision 250/50R15 77D Golf Cart Tires (A65579)
Vision 250/50R15...
2008 Chevy Trail Blazer (A62679)
2008 Chevy Trail...
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
