FEL Float Mode
/ FEL Float Mode #1
Byrdnyrd
Plymouth MA (where they burned the Witches)
BX2370 60" MMM with bagger, BX5450 Front mount Blower, soft cab, 48" Brush hog, Several Gravely's, Lots of Land Rovers, Best wife EVER!!
Hi All,
This may be a stupid question but: How do I get my BX2370 into "Float" mode without lifting the machine off the ground?
I know that to enter float mode, I just push the Hydraulic Valve up beyond the detent, but to do that I either have to raise the front wheels off the ground and slam the machine back down or if I have the FEL in the full up position and push the valve, the loader smashes to the ground with a bang.
I know I can turn the machine OFF and then move the valve, but there as got to be some magic trick to this
And YES I did search the forum for this, but nothing came up, that's why I put a descriptive title in this post
Cheers,
BN
/ FEL Float Mode #2
Just put it up into float before the FEL gets to the ground (raise the loader a little, push lever all the way fwd and it will "float" down to the ground)
/ FEL Float Mode #3
I have a small B, but I assume it is about the same. It seems to work best with kind of a quick snap forward movement. You can do it with the bucket in the air and the bucket will just gradually move down and then be in float If the bucket is on the ground, it will sometimes lift the wheels, but you will get the feel for it. I also frequently do it while moving and maybe that helps.
FYI, I asked how to even get it into float, so you're a step ahead of where I was.
/ FEL Float Mode #4
You have to have your bucket right at ground level, then throw into float quickly. If you don't do it quick it will start to raise the tractor. Float relieves hydraulic pressure, having only the weight of the loader holding it down, thus "floating".
That's why if you have the bucket raised, it will drop freely!
/ FEL Float Mode #5
Hi All,
BN
No question is ever stupid. I went a full year before I even knew I had a "float" position.
/ FEL Float Mode #6
Me too! :duh: Maybe not a year, but quite a long time...
I read about it in a thread here, and immediately went down to the driveway to check it out. It was like a tractor "easter egg".
/ FEL Float Mode #7
On the Kubota you just do it quick, firm, convinced it's going to go into float mode. It's not there for those that are hesitant. Just "do it". You'll see what I mean if you'll just "shove it up". Bucket up, down or anywhere will do it if you just shove it all the way forward. If it doesn't your being to hesitant or yours is tore up. If your tractor is lifting off the ground your shoving to slow/easy/hesitant. Get my point, just "do it".
/ FEL Float Mode #8
One smooth, quick movement through "down" into "float". If it's lifting the front end, you are moving the control way too slow. Do not pause, just do it!
/ FEL Float Mode #9
You just rest the heel of your palm on the joystick, mutter "Git 'er done!" and slap the lever gently upward into float mode. You're through the "down" position quickly. Well, that's the way I do it..
Sean
/ FEL Float Mode #10
Sean
"slap" or "snap" it into float. When either of mine are empty and raised several feet above the ground and I snap it into float they just drop gradually.
/ FEL Float Mode #11
Practice with the bucket about 1 foot off the ground to keep from doing wheelies, once you get the hang of it you can do it while its on the ground.
/ FEL Float Mode #12
Mine drops faster than I'd like.. I usually start with it on the ground or close to it.
Sean
/ FEL Float Mode
You guys are WICKET SMAAART I couldn't wait to go out this morning and test it out...I snapped that stick forward like I meant it and Viola!!! Bob's your Uncle!!
Thanks to all who replied!!
Cheers,
BN
/ FEL Float Mode #14
That is what I do.
/ FEL Float Mode #15
Op's hand must only have the slow motion feature.
/ FEL Float Mode #16
Whats the use for the float mode? Gotta try this.
/ FEL Float Mode #17
Many, but back dragging with the bucket is one. You can use it to evenly spread gravel or dirt. It is not a box blade, and won't move a large amount of materiel but you can adjust the bucket angle a bit to move a bit more or less material. Here is a very short demo of an old fat boy smoothing out some gravel by traveling in reverse with the bucket in "float" with some angle on the bucket.
https://www.youtube.com/watch?v=7Wh-Y0d-pfw
/ FEL Float Mode #18
I use mine with bucket skid shoes for moving snow, it maintains the same height with no adjusting. Backdragging sand is another use.
/ FEL Float Mode #19
I use float when plowing snow or using my snowblower. Stops the implement from digging into the ground.
/ FEL Float Mode #20
k0ua, yep, float is very useful for gravel etc, for leveling.
If I see the ground is not quite level and find float rides the "hill's", here's what i do...
I start at a level spot, drop the bucket "in float" then remove the "float" function and add just a "little'
down pressure, this will keep a level field for those "little' hill's,
then, repeat, but in float only.
It takes practice but works well.
2020 INTERNATIONAL LT625 6X4 TANDEM SLEEPER TRUCK (A59909)
2020 INTERNATIONAL...
2006 Lark United 19ft S/A Enclosed Trailer (A61569)
2006 Lark United...
6051 (A61165)
6051 (A61165)
UNUSED KUBOTA BT3004-24" PIN ON EXCAVATOR BUCKET (A62130)
UNUSED KUBOTA...
2003 FORD F-250 XL SUPER DUTY CREW CAB TRUCK (A62130)
2003 FORD F-250 XL...
1654 (A62130)
1654 (A62130)
