FEL float detent
   / FEL float detent #1
Fall Creek
Granbury,(Acton), TX
Kubota L3240 HSTC
2008 Kubota 3240 HSTC. How do I check if FEL float detent is working? If it's not working, how do I fix it?
   / FEL float detent #2
Welcome to TBN!
If you push the joystick all the way forward you should feel it go into float and the handle should stay up on it's own. If you pick the front of the tractor up a little with the loader, it should fall if float is working.
   / FEL float detent #3
Lower bucket to ground than push joy stick all the way forward than going backwards bucket follow contour of the ground.
   / FEL float detent #4
I'll just add that you might have to do it with a quick pop flick of the wrist. that's how it works in JD. a slow push might not get it into the detent. it just a feel kind of thing.
   / FEL float detent #5
Make sure the bucket is close the ground;a hard straight push forward on the joy stick.
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
Flatbed Equipment Trailer (A50515)
Flatbed Equipment...
UNUSED FUTURE EXCAVATOR RIPPER (A51244)
UNUSED FUTURE...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
2014 TAKEUCHI TS70R WHEELED SKID STEER (A51242)
2014 TAKEUCHI...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
