Deerlope
Also there is no remote control selnoid I just use my rear remote lever.
Deerlope said:Also there is no remote control selnoid I just use my rear remote lever.
ovrszd said:And you could easily make it removeable with quick couplers on the hoses. If you had a grappler setup you could interchange between the two because the hydraulics would already be there.
mikim said:Ken - where did you get that connector for the power lead? I need to get my winch setup and running. I have a plan to put it on a square tube that will then fit into a 2" receiver --- on the back of my truck, front of my truck, back of the tractor, front of the tractor , anywhere I can put a 2" receiver and have access to 12V.
