FEL Dismount Question
/ FEL Dismount Question #1
gltrap54
Topeka,KS
B3200 Kubota
I've got a Woods 1006 FEL on my B7500 that I'm about to dismount for the first time. Do I need to connect the hydraulic lines to complete the circuit after the FEL is disconnected?
/ FEL Dismount Question #2
That's a great question and it has two possible answers (as far as I know). If your unit has couplings for the loader then simply disconnect and replace caps (for dust!). Because this is an after market loader most likely it is not a direct line system meaning you have couplers (where hoses connect to hydraulic system). If you have a direct drive hydraulic system then you WILL need to complete the circuit to drive the remaining hydraulic system. Keep in mind that KUBOTA is a the king of running everything they can off hydraulics. Hope this helps.......
Later
Later
Thanks for the info. Mine does have couplers, so it's just a matter of putting on the dust caps.
I won't go into the time I dead headed the pump on my Case/Ingersoll, which DOES have direct lines and no release valve! :eek:
2013 HYUNDAI HL770-9A WHEEL LOADER (A65053)
2013 HYUNDAI...
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
2022 EZ-GO ELITE...
JOHN DEERE 330G LC EXCAVATOR (A65053)
JOHN DEERE 330G LC...
2018 CATERPILLAR 303E CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
