FEL Dismount Question
/ FEL Dismount Question #1
gltrap54
Topeka,KS
B3200 Kubota
I've got a Woods 1006 FEL on my B7500 that I'm about to dismount for the first time. Do I need to connect the hydraulic lines to complete the circuit after the FEL is disconnected?
/ FEL Dismount Question #2
That's a great question and it has two possible answers (as far as I know). If your unit has couplings for the loader then simply disconnect and replace caps (for dust!). Because this is an after market loader most likely it is not a direct line system meaning you have couplers (where hoses connect to hydraulic system). If you have a direct drive hydraulic system then you WILL need to complete the circuit to drive the remaining hydraulic system. Keep in mind that KUBOTA is a the king of running everything they can off hydraulics. Hope this helps.......
Later
Later
Thanks for the info. Mine does have couplers, so it's just a matter of putting on the dust caps.
I won't go into the time I dead headed the pump on my Case/Ingersoll, which DOES have direct lines and no release valve! :eek:
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
John Deere Lift Arms (A65640)
John Deere Lift...
2007 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2007 MACK GRANITE...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
