FEL Chainsaw
   / FEL Chainsaw #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
https://www.worx.com/en-US/WORX-JawSaw-WG307.aspx
LimbSaws by Priefert | Home
Thinking about ways to adapt a chainsaw to a boom on a front end loader--Would the Worx JawSaw have any potential to be mounted to a boom with some type of actuator to move the chainsaw across the jaws? Also wondering, since it's 120 VAC, whether an inverter powered by the 12 VDC tractor system drain the battery in a hurry. I believe the 5 amp rating of the saw on 120VAC would translate to about 50 amp draw on the tractor 12V battery assuming there is no loss thru the inverter.
Just sort of thinking out loud here as I need to come up with a way to trim those high branches. Would like to hear some thoughts and suggestions.
   / FEL Chainsaw #4
I purchased a limbhog a couple years ago and like it a lot. Takes 7-8 GPM to operate.
Photos & Videos
   / FEL Chainsaw
I have a gas powered pole pruner but need to reach up a bit higher. I only need to trim a few trees around the house and thinking in terms of a poor man's version of the Limbhog. I do appreciate the responses received so far and look forward to more. I hire the trimming along the street which is done with a bucket truck aka cherry picker but it's too heavy for the lawn.
   / FEL Chainsaw #7
   / FEL Chainsaw #10
Do those ever get hung up in a tree when a branch twists? I would hate to get a boom mounted saw hung up 15' high :(
I like the idea a lot but the cost is more than I can justify. IDK if I want a boom mounted saw, I've always thought more about a large chain saw mounted directly on the side of a bucket. I'm looking more for trimming alongside trails rather than a need to get 20' high in a tree.
2015 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A48992)
2015 FREIGHTLINER...
2009 MACK PINNACLE CXU613 TANDEM AXLE  DAY CAB (A45678)
2009 MACK PINNACLE...
12-16.5 Forerunner SKS4 Tires (A49251)
12-16.5 Forerunner...
Wolverine Hydraulic Tiller Skid Steer Mount (A47371)
Wolverine...
Perfecta Harrow (A49251)
Perfecta Harrow...
Extra Heavy Duty Powder Coated Hay Feeder (A49251)
Extra Heavy Duty...
