Front-End Loader FEL Bucket Extension
   / FEL Bucket Extension #1
NonTypicalCPA
SW Michigan
Kubota L3940
I'm looking for a way to increase the amount of firewood I can load into my fel bucket. I want to cut down on the number of trips to the trailer. I have seen in a previous post where someone on here made one, but I don't have the tools or welding skills to make my own. Does anyone know of any products manufactured for sale that would work for what I want to do?
   / FEL Bucket Extension #2
Sorry, but I don't. But have you looked into just buying a larger bucket to fit you loader? Don't know your brand of machine, but a lot of FEL's come with a standard size bucket, with options for a larger or more heavy duty bucket. Also if you have a universal mount on our FEL you may be able to look at different manufacturers buckets as well. That might be easier than trying to fab something.
A different approach might be to use a trailer of some kind that you could load more into than your bucket would hold. Or possibly add a carry all to your 3 point hitch than you could load both the loader and the carry all. Just a thought.
   / FEL Bucket Extension #3
Maybe a sheet of plywood attached with clamps on bottom and sides.
   / FEL Bucket Extension #4
How about clamp on pallet forks, an old pallet with sides made from plywood. No welding required.
   / FEL Bucket Extension #5
Now, add a pallet carrier to the three-point, similarly outfitted and you have a two-fer
   / FEL Bucket Extension #6
How about making a carryall for the back? Search on carryall and you'll find tons of variations.
   / FEL Bucket Extension #7
build a box from plywood and 2x4s that fits in your bucket -- clamp it in some way - and haul away.
   / FEL Bucket Extension #8
Cut a piece of ply thats size of the base of the bucket plus a couple of feet. (Say 4' x 4' ). Then string chains or cable from the front corners of the ply to the top corners of the bucket. (You may have to drill a couple of holes in the top corners of the bucket to attach some shackles.) A couple of small cheap 'G' clamps may also be needed to keep the ply in position. You should be able to knock something like that together in a couple of hours, and attach and remove it in seconds when necessary.
2018 John Deere 8370R MFWD Tractor (A50657)
2018 John Deere...
2012 Dodge Journey SE SUV (A48082)
2012 Dodge Journey...
2017 Mahindra 85P 4WD Tractor (A50860)
2017 Mahindra 85P...
Vermeer SC802 (A50322)
Guard Rail Pieces (A48081)
Guard Rail Pieces...
Diesel Fuel Tank with Pump (A50860)
Diesel Fuel Tank...
