Snow FEL Bucket Cutting Edge Lesson's Learned
   / FEL Bucket Cutting Edge Lesson's Learned #1
urbandeere2520
Charlotte, NC
JD 2520
THE GOOD - Winter this year provided near weekly snow falls on the east coast so I had ample time to test out the snow moving capability of the 61 bucket (BW14146) on a 200CX loader mounted to the 2520 tractor. Let's just say this combination worked flawlessly on moderately steep terrain and handled up to 18 of snow with aplomb. Using only float mode, ice could be removed simply by tipping the bucket down to exert additional cutting force on the long asphalt driveway. I was extremely happy with the performance of the loader and tractor as it quickly dispatched the white snowy mess. :D
THE BAD - Attached are photos of the bucket's cutting edge after only one season of use since new. Basically the cutting edge is destroyed, since it's no longer straight along the front edge. Nearly セ inch is worn off at the bucket outside edges. Attachments, such a tooth bars, can no longer be affixed with a non-linear cutting edge. I was very surprised about the amount of wear on the cutting edge after only one winter season's use. Not happy. :(
THE UGLY I contacted my local John Deere dealer to inquire about the cost to replace the welded on bucket cutting edge. The estimate was about $600 parts and labor, and the bucket would have a "repaired" look to it when finished. The dealer provided the cost of a new bucket at just a shade over $800. Assuming worst case scenario, aka a heavy snow falls each year; I'll be spending $600 to $825 to move snow annually. There has to be a better way. :eek:
I'm evaluating different options before the next winter season. Below are a few options under consideration.
  • Repair bucket with a factory cutting edge and install a wear bar for snow removal. I believe W.R. Long manufactures a wear bar. $600 plus $300 = $900
  • Remove the damaged cutting edge and replace with a removable cutting edge that can be changed when worn. Cost and availability unknown.
  • Purchase a new bucket and wear bar for snow removal. Sell damaged bucket for few hundred $. $825 plus $300 = $1,125 (less proceeds from old bucket sale).
  • Purchase a new bucket. Sell damaged bucket for a few hundred $. Move to a snow free State currently under consideration. $825 (less proceeds from old bucket sale).
  • Do nothing. Forget about installing a tooth bar or wear bar with the bucket and continue to use it to remove snow on asphalt as usual. When the cutting edge wears back to near the wear plates, maybe 1 to 2 years more of snow removal, then make a decision to repair cutting edge or replace bucket.
If anyone on this board has other recommendations or constructive comments, I'd love the hear them. :anyone:
Damaged Cutting Edge-1.jpgDamaged Cutting Edge-2.jpgDamaged Cutting Edge-3.jpg
   / FEL Bucket Cutting Edge Lesson's Learned #2
Get you stick welder out and your 7 inch grinder, and build up the edge, and grind to match.. rattle can it when done for looks. cost not much depending on which rod you use.. 2 hours of time, maybe.
They make rod just for this purpose of hardsurfaceing, but I would probably just use some 7018. it wont last as long, but it is cheap, and you can do it again!
To me this would be no big deal, and I am a novice welder. EVERY tractor owner needs a welder. Whether they know it or not.
https://weldingsupply.com/cgi-bin/einstein.pl?PNUM::1:UNDEF:X:ED021996
   / FEL Bucket Cutting Edge Lesson's Learned #3
John deere is famous in the USA market.I want to know how about the agricultural equipment of John deere market in Russia?As far as I know,Russia also have several big company who sell agricultural machine.
You would need to start another thread, this thread is about a guys worn bucket cutting edge and how to fix it.:)
   / FEL Bucket Cutting Edge Lesson's Learned #5
I would say go with a reversible bolt on cutting edge.
   / FEL Bucket Cutting Edge Lesson's Learned #7
After only one season and it looks like that :eek:
How many hours do you suppose you worked it?
I plow commercially with a truck plow. A 3/8 thick cutting edge starts at 6". And 3" is wore out. Not uncommon to get 200-300 hrs on an edge (3" wore away). And that's with the edge near vertical and not horizontal. So you either did some serious plowing, or JD used some softetal for that edge.
If it were mine, I'd drill the existing cutting edge (mag drill is your friend) and add a bolt on edge below the existing. Either that or get two more years out of it and drop the $800 for a new bucket. 3 years of snow removal for $800 ain't bad.
Either way, something has got to wear. Weather it be the factory edge, a bolt on edge, or an attachment. A bolt on edge is likely going to be the cheapest, and still pretty easy to replace.
   / FEL Bucket Cutting Edge Lesson's Learned #8
My cutting edge seemed to start wearing incredibly fast so before any real damage occurred I tried to find a replaceable cutting edge, long story short is not available any that I could get from local heavy equipment suppliers were way to heavy and costly. I finally went to the welding shop bought a 5" by 1/2" piece of mild steel flat bar sharpened on old drill bit and drilled the bucket edge and flat bar. It's drilled dead centre so when one side wears out I just unbolt it an flip it sides. I bought some small cutting edge mounting bolts and after the holes were drilled used a larger bit the size of the head to counter sink the heads into the wear bar. I forget what the steel cost but it was so cheap that if it lasts half as long as a hardened wear bar I'm still further ahead.
   / FEL Bucket Cutting Edge Lesson's Learned #9
Find and buy cutting edge material in 1/2 in. X 4- 6 in. Width. It will be costly and usually sells by the inch. From a steel supplier. Then find a welding shop to cut off the old and weld on the new. This new one will probably outlast the tractor.
Also weld a strip of cutting edge to the front bucket sides and several strips on the bottom for wear. Be aware that drilling holes in a proper cutting edge is not easy or advisable. Torch yes.
I've done this on two small tractors. It will make a much much stiffer bucket. :thumbsup:
   / FEL Bucket Cutting Edge Lesson's Learned #10
One winter of clearing snow on a residential driveway in northern Virginia, and the bucket edge is ruined? It's a quality issue with John Deere, there is no way in heck that I would spend good money to repair or replace a bucket every spring because I used it to clear snow from my driveway.
John Deere needs to look at this, a bucket should last many years.
2006 Intellistrobe Automatic Flagger Assistance Device S/A Towabale Trailer (A55973)
2006 Intellistrobe...
2017 Ford F-250 (A55973)
2017 Ford F-250...
Heavy Duty Excavator Ripper (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty...
2016 Ford Taurus Sedan (A56859)
2016 Ford Taurus...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
