FEL Bucket 54" or 60"
   / FEL Bucket 54" or 60" #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Hi All.
I am considering the purchase of a B2650 with a FEL.
My Bucket options are a 54" "Standard" bucket of a 60" "Light Duty" bucket.
Does anyone know what the real difference is between the two of them? (Other than 6"?)
Which do I get?
And on the 2650 HSDC "CAB" model, does the rear window open up enough that I could stick my hand/arm out of it?
I ask because I have a 3PT Snowblower with a manual chute that I would need to crank by hand.
Or, I guess I could somehow convert the chute to a hydraulic or electric style if I had to.
Thanks.
   / FEL Bucket 54" or 60" #2
OK - on my 2009 Kubota M6040 I had two bucket choices. Standard round 72" or heavy duty 72". On paper they looked exactly the same. The standard bucket was 210 pounds; the heavy duty is 453 pounds. I went with the heavy duty model - more steel.
72" is just about 4" wider than my front wheel overall width. So if the bucket clears - so should the front. However - the rear is 80" over all width and would hang up.
I would recommend that you go with the standard bucket
oosik,
Thanks for the info !
   / FEL Bucket 54" or 60" #4
Tim - no matter what anybody will warn you about the limits of digging with your FEL. One day you WILL dig. You will be pleased that you had a heavier bucket that does not fold up like an accordion. I have quite a few ground engagement implements and have NEVER regretted getting the heavy duty version.
Perhaps this will be your first warning - - remember your tractor is just that - - a tractor. Not a bull dozer. Unfortunately - the hydraulics and FEL arms can be damaged by over aggressive use. The FEL is designed to work with loose piles of material and light, easy digging projects.
oosik.
I have to admit... I have done a fair amount of "digging" with the FEL on my B2150. I know it's not what they are designed to do.... but sometime you just can't help yourself.
Luckily, neither my tractor, nor me, has sustained any damage. :.)
   / FEL Bucket 54" or 60" #6
The 60” bucket is not a “light duty” bucket . It is a “light materials” bucket.
This is kubotas legal way of saying don’t get the 60” bucket and fill it full of the heaviest material you can find. Even though I have with my B2650.
If you don’t have any space limitations go with the 60” bucket. The extra width to cover your tire tracks alone is worth it.
Again. It is a light material bucket. Not a light duty bucket.
   / FEL Bucket 54" or 60" #7
I would bet it is NOT a HD bucket though.
Hi Dan.
Yes, you are right. I misquoted.... it does say light "Materials", not Light duty.
I'd love to see the 54" and 60" side by side to compare the gauge of the material used.
   / FEL Bucket 54" or 60" #10
The difficulty is - there is no definition for heavy duty. On the two bucket choices I had - the heavier bucket simply had thicker steel - more bracing - added gussets - more welds.
2006 Dodge Ram Pickup Pickup Truck, VIN # 3D7KS28C66G203434 (A57453)
2006 Dodge Ram...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
30in Forks and Frame Mini Skid Steer Attachment (A56857)
30in Forks and...
1026A (A58374)
1026A (A58374)
Kubota M108S (A53317)
HUSQVARNA RIDING...
