FEL boom pole w/basket
   / FEL boom pole w/basket #1
LetsRoll
Kentucky
2005 New Holland TC48DA 2wd 12x12 tranny
This is a boom pole with a basket on the end of it. I welded it together to help trim the tree lines. Its attached to the FEL by means of the FEL pallet forks. The forks are rated at 3500 pounds, so I don't have to worry about them bending or snapping off. I'm not completely done with the basket yet. I still need to weld some more square tubing in the middle of the basket. Just incase someone slips, they don't fall out of the basket. I also need to add more support brakets to the end fingers. The way I have it set up, I can remove the basket from the boom pole. The swing bracket will always stay connected to the basket. The end of the boom pole is some what like a reciever hitch. The total height I can get is about 23 feet. But I don't plan on going any higher then 20 feet. I do have the tires filled and have had 120 pounds in the basket raised up to 20 foot so far. FEL was stabble, but I need to add some support to the FEL pallet forks. I do plan on using more ballast weight to the rear end of the tractor (the more weight I add to the basket).
Re: FEL boom pole w/basket *DELETED* *DELETED*
Post deleted by LetsRoll
   / FEL boom pole w/basket #7
You are nuts. I'm sorry but even if you had perfect welding and design, tractor hydraulics do not have the safety valves for a burst hydraulic hose or failed pressure relief etc.
DON'T PUT A PERSON UP IN THAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
   / FEL boom pole w/basket #8
Awe shucks, I would ride in it. How fast does a loader drop if a hose does bust. Might be a fun ride depending..
   / FEL boom pole w/basket #9
It is a great idea but I don't think I would want to be the one in the bucket.
   / FEL boom pole w/basket #10
Very interesting 'contraption' and could provide for some very daring 'experience' for whoever is in the 'basket'. One would have to have a lot of trust in the welds, in the hydraulics as mentioned, and in the tractor driver who is activating the controls. The tiniest move on the control lever will be a huge move in the basket, as well as moving the tractor relative to the basket. But it's your pleasure, IMO.
It looks a bit frail to me. /forums/images/graemlins/tongue.gif
10-16.5 Tires on Wheels (A49251)
10-16.5 Tires on...
LS Mtron XG3140 MFWD Compact Diesel Tractor (A49339)
LS Mtron XG3140...
Kivel 48in Pallet Fork Attackhment (A49251)
Kivel 48in Pallet...
BTTL15H-6 Excavator (A49251)
BTTL15H-6...
2015 John Deere 5055E  4WD Tractor (A49251)
2015 John Deere...
2013 Hyundai Sonata Hybrid Sedan (A46684)
2013 Hyundai...
