FEL boom pole w/basket
   / FEL boom pole w/basket #31
Same basic design except it is about 30 feet shorter. /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
   / FEL boom pole w/basket #32
With it being in close you dont have the control magnification issue. There is still the issue with the hydraulics failing on the FEL though.
That said I would get in to that to get lifted up but not travel in it. I made a 4x8 platform that I pick up with my pallet forks and stand on it, it has saftey chains so it can't slide anywhere.
   / FEL boom pole w/basket #33
As a boompole for lifting light loads up to high rooftops (like one square of composition shingles) Letsroll's idea would also get cautious praise in my opinion. It's the arm's length that makes it absolutely dangerous for a manlift.
In your picture of the bucket lift, there is a strap from the bucket arm to where? Top of the bucket? I think not, probably to the lift arms or crossbar so it holds the bucket to keep it from curling down or sagging due to hydraulic leakdown of the cylinders. It also looks like the overall height is not much more than a 12' stepladder. Even with this relatively safe arrangement, I think I'd want small orifices on both curl and both lift cylinders between the cylinder and the hoses so everything would move slowly in the down direction. Putting orifices on both cylinders would ensure if one cylinder failed internally or either hose failed, the other would only "slowly" bleed down. A safer arrangement for using the loader as a manlift would be pilot operated checkvalves on each cylinder just like our toplink cylinders from CCI. /forums/images/graemlins/cool.gif
Even with all those precautions, I'd want to make sure I stayed on good terms with the operator on the tractor. /forums/images/graemlins/wink.gif
   / FEL boom pole w/basket #34
Jim,
Look real close and you can see the yellow strap coming back under the bucket and hooked on the bucket lip.
   / FEL boom pole w/basket #36
Lots of leverage difference.
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
METRIC DUAL CUT TAP & DIE SET (A58374)
METRIC DUAL CUT...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
