FEL 3110D
/ FEL 3110D #1
Gizmo36
Platinum Member
East of Duewest S.C.
Any one have a front end loader on there 3110. If so has any one ever tried to pick up round bells with it. I am thinking of putting a front end loader on .Danny has a good price on them.
/ FEL 3110D #2
Gizmo you are so funny. :D it is funny how our fingers and our minds do not cooperate sometimes and it is not flagged because it IS a word, just not what he wanted!!:eek:
He meant, I believe, whether the fel could pick up round BALES.
Mike:D :D
/ FEL 3110D #3
500 lb bales would be OK. 1000 lb would be questionable. Especially if moving them very far.
/ FEL 3110D #4
I have a Koyker 160 on the front of my YM 3000, the same FEL that is sized to your 3110. I've lifted 1200lbs. with the front end blocked, but a lift over 1000 lbs. would be something you wouldn't want to drive the tractor with. You have a little more weight than I do, but the weak link here seams to be the tires. Tires flaten out ( with 35 psi ) with that much weight. Load I lifted off a pick up, had to block the front end of the tractor, lift, and drive the truck from under the load, move load directly to the ground. They make a "bale spear" for the 3 point for this job but you might have to much weight on the 3 point with a 1000 lb. round bale. Odds are if you want to lift 1 bale, you most likely want to do this regularly. If that is the case, think you should look for a larger machine or use smaller bales. Not worth takeing the chance.
Chris
/ FEL 3110D #5
I have a YM330d with a loader that we use for round bales on the 3 point. It can handle a 1000 bale pretty well. If the bale is much heavier, I have to put extra weight in the bucket.
/ FEL 3110D
The MF 283 burns so much fuel . I try to use the smallest tractor I can for the job. Last year I got diesel fuel at 172 for off road . now it is over 3.00 $ a gal. with diesel and Fertilizer I will have more in hay then I can make off it.
CAT 735/740 Final Drive (A68134)
CAT 735/740 Final...
2017 HINO 338 REFRIGERATED 26FT CDL REQUIRED BOX TRUCK (A69167)
2017 HINO 338...
WORKBENCH WITH VICE (A68842)
WORKBENCH WITH...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
1997 LEDWELL 48FT DOVETAIL TRAILER (A67714)
1997 LEDWELL 48FT...
