Feedback on G274/2704
/ Feedback on G274/2704 #1
KrisR
Hudson Valley, NY
I'm looking at a used G274/2704 and was looking to get feedback from people on the forum. I'd be using it for snowplowing, brush-hogging, and general use around my property. Any info or feedback on this model or Iseki Bolens is appreciated. Thanks
/ Feedback on G274/2704 #2
/ Feedback on G274/2704 #3
Tractortips.com
I think a White Field Boss ( FB ) 31 is the same tractor. The above link under "specs..." is helpful for specs and checking serial # and years.
Does a loader come with it, how many hours, what's the rubber look like and what are they asking ?
/ Feedback on G274/2704 #4
Here is a pic of my G214
RCH,
Thanks for the input, keep it coming. I haven't had a chance to look at it yet, hopefully soon. According to the owner it has 286 orig miles, cab, loader, and snow plow. The asking price is $7700. I think it's a bit on the high side. I've been trying to get some comparisons. Hopefully the link below will give you a pic.
http://www.wantaddigest.com/photolib/AAZJL92A00295.jpg
/ Feedback on G274/2704 #6
KrisR, for comparision last week a 1988 Ford 1720(Shibaura) with factory loader, 730 hrs, Ag tires and adjustable width, shuttle transmission brought $10,300 at a private auction. That is 4 - 5 horses less. On mine the hour meter only goes to 3 ( 999) digits so anything above restarts at 0. 286 hrs seems low for a 16 y/o tractor
Partial specs of a White FB31 from tractortips.com;
Tractor Specification
Make: WHITE FWD/REV Standard: 12/4 Hitch Lift:
Model: FB-31 FWD/REV Optional: Hydraulics-Type:
Years Made: 1986-1988 MFWD-STD/OPT: OPT HYD-CAP:
HP-PTO: 25 Tires_SD/OPT: 5.00-15 Tires-STD Front:
HP-Engine: Tires-STD Rear: 11.2-24 HVD Std Outlets:
HP-Drawbar: Wheelbase - Inch: Cooling Capacity:
Engine-Make: ISEKI PTO Type: IND Fuel Tank Capacity:
Engine-Fuel: DIESEL PTO Speed: 540 Cab-Std A/C, ROPS:
Engine-CYL(s)-CID: 3/91.4 3PT Hitch CAT I: Yes
Transmission-STD: New Price: $10,950.00
A loader is a $2500 item plus the cab and blower !
Make sure there is no damage to the radiator from battery acid. Check the fan belt and knuckle on the steering gear arm ( by the clutch) and pedal wear re 286 or 1286 hrs. I have 1200 hrs and 6000 - 8000 hrs withcare is possible to an engine. Good Luck and let us know what you do.
I have a front PTO kit that is live off the front of the engine with an electric clutch that fits. /forums/images/graemlins/smile.gif
RCH,
Thanks again for the info and insight. Hopefully I'll take a look at it this weekend. I'll let you know what happens. Is it safe to say you are happy with Iseki-Bolens/FB/White.
Kris
/ Feedback on G274/2704 #8
KrisR, Yeh I'm impressed with my little Iseki. From thr tires, the cab and snowplow it would seem this was a prime snow removal machine and that may explain the 286 hrs. Block heater and cab heater are nice to have and often indicate set-up for winter use.
/ Feedback on G274/2704 #9
I have a Bolens G174 and I am very happy with this tractor. The price is reasonable.
I would give it a grade of 10. A picture of mine.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
7ft Fork Extensions (A61572)
7ft Fork...
Fendt FT500 Tractor Light Kit (A63117)
Fendt FT500...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2018 John Deere R4030 Sprayer (A63111)
2018 John Deere...
