Faulty flourescent lighting balasts
/ Faulty flourescent lighting balasts #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
I have a bunch of those energy efficient four tube flourescent fixtures at my shop with the skinny tubes. Some of them were there already and some I bought frome Home Depot.
All the ones I bought from Depot have gone out one at a time. They have you assemble them yourself, so i'm wondering about if theres a way to miswire the balast. It's got vague directions. So on the burnt out ones I went back to Depot and got just the replacement balasts (Advance brand, replacing sylvania) I hook all the wires with butt splices color to color. Are these just not reliable fixtures or any ideas??
The bulbs are pretty fresh too.
/ Faulty flourescent lighting balasts #2
Sounds like you might have a wire in the but connector crimped, but not making any connection /forums/images/graemlins/confused.gif I have always had good luck with the heavy ballast. The lights I have trouble with, are the 4' shop lights with the cheep transistorized unit on the side. Maybe you can check the connections with an ohm meter, with power off. check the bulb ends, and the little spring steel sockets that the bulbs fit into, the yellow on one side and red & blue on the other just push into the bottom of the socket, and not making the connections. Bully
/ Faulty flourescent lighting balasts #3
I've had the same problem with those cheapy 4' all in one lamp units. And no place to drop in a replacement ballast.. event he small ones. I'm not sure if 7.99$ is a good deal or not for a lamp that lasts a year then you have to change the fixture /forums/images/graemlins/shocked.gif
Soundguy
my fixtures are the ones with four- four foot skinny tubes each fixture, (f32T8) so the overall length is eight feet and the balast is a replaceable rectangle box type. I dont think its the splices because they pass a pull apart test.
The two that went out yesterday were during some connecting new wiring to the junction box they are wired in so power was interrupted on the neutral side intermittently for a spell.
/ Faulty flourescent lighting balasts #5
</font><font color="blue" class="small">( The two that went out yesterday were during some connecting new wiring to the junction box they are wired in so power was interrupted on the neutral side intermittently for a spell. )</font>
Do this test:
Disconnect that neutral again, and test the voltage on the hot leg to ground.
There is a chance you will see 220V /forums/images/graemlins/shocked.gif, not 120v as you would expect! If so, I will explian in further detail...
/ Faulty flourescent lighting balasts #7
Hooking up a 3 wire circuit, two hots and one neutral to two breakers on the same bus is in violation of code. The reason is the neutral could then carry the sum of the current on the two breakers. So for #12 wire and 20 amp breakers the neutral could carry 40 amps. In your fan/light example both the black and the red would have to be fed from the same breaker if you did not want to have the 120/240 supply.
/ Faulty flourescent lighting balasts #8
midlf is correct, that is a code violation, at least with the NEC®. And it could cause a fire due to overloading the neutral in that multi-wire branch circuit. Code requires them to be on opposite phases for a reason.
Truly great knowledge i would have never considered...code or not. Thanks all!!
/ Faulty flourescent lighting balasts #10
Funny. One of our offices at work has a couple of Home Depot fixtures with electronic ballasts and one of the fixturres just toasted a balast. We were just commenting how it would be nice on what should be a long life balast if it would at least outlast the first set of tubes. It was about a year old.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
2014 John Deere 6105D (A64126)
2014 John Deere...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
