Fault code LS XR4140
   / Fault code LS XR4140 #1
24 frames
hockley Texas
LS5030 JD 2440
Tractor will not start XR4140 I get a Yellow blinking light and a 168 FO3 Fault code does anyone know what code refers to ? thanks to all Happy Holidays
   / Fault code LS XR4140 #3
S168 F03 with a SOLID yellow light is Battery voltage High Fault (P0563 with a reader) -- at least for the 41xx series
  • LS codes.pdf
   / Fault code LS XR4140 #4
this is the test/repair routine. check grounds as LS always has issues with the grounds
  • ls s168-f03 dignostic.pdf
Thank you all for response Even with my limited computer experience I saved the code list Eagle 1 sent me I hope today I will get time to clean and inspect grounds Happy Holidays to all
4ft Mini Skid Quick Attach Rotary Cutter (A56438)
4ft Mini Skid...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
2001 International 4000 DT 466E (A60462)
2001 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56438)
Midwestern...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
