Fastener Supply
/ Fastener Supply #1
SLOBuds
Los Angeles/Central Coast, California
Kubota L35
Just bought a L35 and want to establish a fairly comprehensive set of replacement parts. Stuff that breaks or wears out.
What is recommended - or how would I go about laying that out?
Do I need to measure each pin - or are these all standard sizes?
I've got L35 with standard loader and backhoe, plus box scraper, plus brush hog.
/ Fastener Supply #3
Most manufacturers have a recommended spare parts list for a particular model of equipment. Contact your salesman, he should be able to point you in the right direction.
Warning: These lists usually have loads of stuff on it, you will have to go thru it and decide how much money you want to spend.
/ Fastener Supply #4
The only spare parts I keep are a set of filters (engine and trans), and engine and trans oil, and a bunch of lynch pins and hairpins of a couple of sizes.
Bill Tolle
/ Fastener Supply #5
I've broken a couple of grease zerks on my FEL... and got a set of replacements from HF.. .they have an assortment for not much $$
Also, an easy-out that fits the busted zerk would be good to have, just in case. You WILL need it if you break one.. HF, also, has a set of easy-outs... I think 5 different sizes, also not many $$.
Works for me. Other than that, oil, filters, grease gun, rags, should do the trick.
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2015 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2015 CATERPILLAR...
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
