Farmtrac HELP
/ Farmtrac HELP #1
Deerlope
Northern, New York
Kubota L3830 03: RTV 900
I got a friend online that knows very little about tractors. He has a farmtrac 36 HP he says. He has two remotes and he does not know where to located the lever controls for them and neither do I. Can someone please give me a clue as to where they are located?
/ Farmtrac HELP #2
Sometimes there are levers in the floorboard. Best advice is to trace the hoses from the remotes to the valve and levers that operate them.
/ Farmtrac HELP
The guy sent me some pics and I seen two levers just to the right of the seat. He said that one is for the 3ph what is the other one for?
/ Farmtrac HELP #5
one is three point lift, the other is draft control
below and just inboard under your right leg are two levers for rear remotes
/ Farmtrac HELP
Thanks for the help guys. If he can not find it now maybe he should not be using a tractor.Merry Christmas to all.
/ Farmtrac HELP #7
Hi DEER!
On my DTC 360, the 3ph and draft control are to the right side of the seat between elbo and thigh height. The levers for the remotes are also on the right, below seat level, in the calf area. Right heel is diff lock, left heel is 4wd lever.
Hope it helps
Mark
2022 EZ-GO ELITE...
2012 MACK GU GRANITE 6X4 T/A ROLLOFF TRUCK TRACTOR (A67148)
2012 MACK GU...
Kivel Quick Hitch Mini Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A67148)
2017 FREIGHTLINER...
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
2016 CASE CX37C EXCAVATOR (A65053)
2016 CASE CX37C...
