Farmtrac 555 steering leak
   / Farmtrac 555 steering leak #1
beggar
picayune,ms.
farmtra555-case1494-kubota M4050-F4610-MF285
I have a Farmtrac 555 that is leaking oil around the steering post under the steering wheel. I have looked at the parts diagram and it shows only a dust seal under the steering wheel in the steering post. It doesn't show a seal or o-ring where the post goes in the steering motor.Must be one there and is part of steering motor. Has anybody been there and did that.
Thanks , Beggar
   / Farmtrac 555 steering leak #2
Have not may be like others and you have to buy the whole thing. If it is bad try to take it apart and see if you can match it up.
   / Farmtrac 555 steering leak #3
Ouch at 1k I would be trying to find out if is serviceable
I talk to a tractor mechanic and he said it had a seal by the steering box that could be matched up at the parts store. when you pull out the steering post loose bearings will fall out if you are not very careful with it. sounds better than expensive parts.
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2014 Komatsu D51PXI-22 (A55272)
2014 Komatsu...
2018 HINO 338 26FT CDL REQUIRED BOX TRUCK (A59575)
2018 HINO 338 26FT...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A57453)
2004 Freightliner...
1770 (A58375)
1770 (A58375)
