FARMTRAC 555 IGNITION SWITCH
/ FARMTRAC 555 IGNITION SWITCH #1
beggar
picayune,ms.
farmtra555-case1494-kubota M4050-F4610-MF285
I replaced my key switch with a ford switch. it's different so I plugged the wires into the same numbers and it don't want to crank without grinding on it for 10-12 seconds. At first I had the starter plugged in to second position of switch (two click on switch) and it crank good and moved key back to position one after starting. I don't want to leave it like that. I put the start wire on post 4 which is preheat (it seams) or post 5 silenoid it acts like it's not getting fuel. The electric fuel shut off and fuel preheat is on post 1. I check with a 12 v test light and they work when key is turned on. I thought I would save a few bucks buying a ford switch but things ain't looking good. any helpful ideas
/ FARMTRAC 555 IGNITION SWITCH #2
There are Farmtrac parts available, that is the route I would take. I have owned several and still have a 555DTC older design for sure but still solid machines.
yes I will have to get another switch to make it work correctly. the switch I got will shut off all other wires when you turn key to crank which shuts off the fuel supply so it will not crank
I put the starter wire on the ON wire and turn the key back one step to acc. after it cranks till I get a new one. The one I got must be for a tractor with a pull kill and it has a spot halfway in the spring load start for glow plugs and mine don't use glow plugs.
/ FARMTRAC 555 IGNITION SWITCH #4
Beggar....leave it be.... Tie the fuel solenoid wire to the thermostart wire with a Jumper... Thats what I did.
It puts 2 wires on the same terminal but the thermostart wire is only energized when you are actually rolliing over the starter. I had the same problem.....it would roll over fine and not start but soon as you let off the key it would fire...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
FUEL TANK WITH PUMP (A68842)
FUEL TANK WITH...
2013 HILL COUNTRY (A67714)
2013 HILL COUNTRY...
John Deere 5400 (A64911)
John Deere 5400...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
