Farmtrac 545DTC Hydraulic?
/ Farmtrac 545DTC Hydraulic? #1
whitdog02
Ford Farmtrac 545DTC
I was looking at Farmtrac 545DTC hydraulic pictures. Why does the one on my tractor look different from what’s listed in the parts manual and picture that I looked at? I think the pump is getting weak. It’s not wanting to work right when you start it up. It takes a while before you can lift the bucket or 3point. If I am wrong about it being the pump or it’s something else please let me know.
Does anyone know?
/ Farmtrac 545DTC Hydraulic? #3
Which page of the parts manual are you comparing it too? The hydraulic pump on my Farmtrac is on the underside of the tractor. It took me a bit to find it but I followed the hydraulic lines until I saw something similar to the part in the manual.
/ Farmtrac 545DTC Hydraulic? #4
Picking up a copy of the workshop manual will probably help as well.
/ Farmtrac 545DTC Hydraulic? #5
I had the same issue as Bazman. I mean, I couldn't find it initially. However, when I decided to follow the damn hydraulic lines, I finally found it, and it's truly similar to the one I have seen in the manual. Yeah, it's not identical, but pretty similar, and I knew how to work with it due to the manual. Actually, I had a truly hilarious situation with the hydraulic. I couldn't find anything similar as in the manual, so I called the guys from https://www.machinerydealer.co.uk/compact-tractors-for-sale/ and started yelling at them. When I found it, I was like, well, I ****** up.
S/A Utility Trailer (A59231)
S/A Utility...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
FENCE PANELS (A58214)
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
