Farmtrac 300DTC Broken F-R Lever
   / Farmtrac 300DTC Broken F-R Lever #1
cpehouston
Farmtrac 300DTC
Yesterday while changing from forward to reverse the lever arm broke off just inside the gearbox. Does anyone know where I could buy a replacement? The part no per the manual is LG2191 or A1290101. Thank you in adavance.
   / Farmtrac 300DTC Broken F-R Lever #2
Do you have a local LS dealer? Your tractor was built by LG that later became LS Mtron, so they should be able to help.
Secondly, if you don't have a local LS dealer there is a chance a New Holland dealer could be willing to work with you to see if there is a matching part, as New Holland compact tractors are built by LS.
   / Farmtrac 300DTC Broken F-R Lever #4
Also, consider posting this in the LS section; it's worth a try.
I did find a local LS dealer and have the parts ordered. Hopefully it won't be to difficult to replace!
   / Farmtrac 300DTC Broken F-R Lever #6
I have a Montana 3040. Same tractor made by LS for Montana. A couple years ago I broke the same shaft in the same place. Ordered the part and started reading the service manual. When rebuilding the transmission the first part into the empty case is this shaft and the lever it is connected too. Which I read as splitting the tractor and moving the gears. Plan B was cut the shaft and put a splice on it with pins. The shift leaver is now a couple inches lower, but it works. That was 2 years ago and it is still working and the new shaft is sitting on a shelf in my shop. If you find a way to replace the shaft with out splitting the tractor please let me know how.
gary
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2007 GEHL CTL-60 SKID STEER (A51246)
2007 GEHL CTL-60...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
