Farmtrac 300 lift arms
   / Farmtrac 300 lift arms #1
gwp3va
The lift arms on my 3 point hitch are locked in the up position and won't come down. Anyone have any ideas on what might be the problem?
   / Farmtrac 300 lift arms #2
My 360 DTC has a knob that controls the speed of your lift arms it is located between your legs just above the hump on the floorboard of my tractor, had the same problem you are describing, opened the valve problem resolved, maybe yours will be this simple.
Thanks for the info. Unfortunately, that is the first thing I tried. The knob seems to be locked up and I can't turn it at all.
   / Farmtrac 300 lift arms #4
Since your knob isn't functioning properly I'd bet all your problems are right there. Try turning it CCW (while looking at the knob}, sometimes they are a bit stiff.
John
Thanks for the replys guys. It turns out I over extended the lift piston and messed up the o rings. After O rings changed, works fine.
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2025 K1230 UNUSED (10) Wire Mesh Netting Rolls (A53117)
2025 K1230 UNUSED...
2025 K3325 UNUSED Double Garage Steel Barn (A53117)
2025 K3325 UNUSED...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
