FarmTrac 270DTC PTO Clutch Adjustment
   / FarmTrac 270DTC PTO Clutch Adjustment #1
Jims1910
VA
Ford 1910
A friend of mine asked me to look at his FarmTrac 270 DTC. It takes very little force to make the PTO clutch slip. This tractor has the dual clutch, which he just had worked on. He said the PTO worked fine before he had the clutch problems repaired. Is it possible to adjust the PTO clutch on this tractor?
Thanks,
Jim
   / FarmTrac 270DTC PTO Clutch Adjustment #2
Im unsure of adjustment. Ask the person that installed the clutch. Maybe a shear pin? Or maybe a mower overran and burned up the PTO clutch?
I see some dealers install a PTO overrun clutch to prevent mowers pushing a tractor and damage to the PTO clutch.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
