Farmpro 2425 steering leak
/ Farmpro 2425 steering leak #1
Kyle87
Poughkeepsie NY
None
Good morning, I have developed a pretty fast leak that Initially appeared to be coming from The steering box at the bottom of the steering shaft. However Now the steering shaft is leaking from the top as well, just below the steering wheel where the rubber boot is. I was hoping maybe it was just a loose line but seems to be more of an issue. I did read one thread about the fluid going up the column but could not find the cause/solution.
If I do need to change the steering box, does that require removing the fuel tank? The bolts seem impossible to get to.
Thanks
/ Farmpro 2425 steering leak #2
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2014 Ford F-250 Utility/Service Truck, VIN # 1FDBF2A67EEA87424 (A65563)
2014 Ford F-250...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2016 JLG 800AJ 4x4 80ft Articulating Boom Lift (A64553)
2016 JLG 800AJ 4x4...
Hay Rack Wagon (A66408)
Hay Rack Wagon...
