Farming????
/ Farming???? #1
xgraysonx
larimore northdakota
Farmall B
So we have a few acres at our family farm and it might need to get reseeded this summer. Can the tilling be done just with like a 4 blade cultivator? Pa I might sound stil but I don't know about this stuff :p
/ Farming???? #2
Few acres: like 2,3,4,5 more?
4 blade cultivator: I assume you mean a rototiller. Is it a walk-behind or tractor mounted?
Reseeded: with what?
/ Farming????
Honestly size wise I'm not sure it's like prolly 2-3miles x 1 mile? I have to take a look at the property lines and it would be all tractor mounted stuff, and seeded with crp seeds. Sorry if in not being very informing I don't know much about this haha
/ Farming???? #5
Not a few acres.
larry
/ Farming???? #6
1mile x 1 mile = 1 section = 640 acres.
1 mile x 3 miles = 3 sections = 1920 acres.
That's quite a spread:eek:. Something doesn't compute here. I thought we were talking about a few acres that you want to till.
/ Farming???? #7
He might possibly be referring to his Grandparent's family farm. He mentioned this fact in another post in another member's thread. Just a thought?
/ Farming????
Yes it's family farm and I'm not sure how large an acre is so I just said a few haha and it's more like 1.5mi x .50-.75 mi. This is al guesses :/ I'll talk to my gramma about the exact numbers tomorow.... I feel like an idiot :p
/ Farming???? #10
Lease it to someone. It's done here for corn and works great. They do everything. If it's. Hay ground you can make a deal for part of the hay if you have a use for it. Being unfamiliar with farming I wouldn't try learning with that much land. Just watch and learn from people that do it for a living. Then try a small piece if you want.
Just a thought, I wish I had that much ground to use.
Best of luck.
/ Farming???? #11
I'm still not clear on what you are attempting, but it sounds like you need to talk to the appropriate people. I'll second talking with your local Farm Services Administration (FSA) office. This could also be important to make sure that there are no restrictions on what you are wanting to do, as well as finding out if there are any programs that can help you with cost sharing. Check out the FSA website for more information, but be sure to talk to someone so you have a better handle on how to proceed.
The FSA office might even redirect you to the Natural Resources Conservation Service (NRCS) office who work with restoring land back to native grasses if that is what you are wanting to do. They are usually located in the same building as the FSA office. With both the FSA and the NRCS offices, they will most likely have other area farmers or contractors who will plant the seed for you on a cost sharing basis. We have used a variety of these programs over the years, and I have been generally pleased with their assistance and the farmers/contractors they recommended. You need special equipment to drill the seed to get good germination. If you try to just broadcast and turn the seed under with a light disking, you will most likely be disappointed with the results. It will almost certainly be more cost effective to do it right the first time by letting folks with the correct equipment do the job.
Good luck!
1500 GAL WATER TANK (A68842)
1500 GAL WATER...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
Generator (A64553)
Generator (A64553)
2015 BIG TEX T/A UTILITY TRAILER (A67714)
2015 BIG TEX T/A...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
