farming with JD2210
/ farming with JD2210 #1
ovrszd
Epic Contributor
Missouri
Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Had a little seeding job to do so dragged out the ole tandem disc. The JD2210 didn't seem to mind too bad. It worked better after I built a weight rack and added 250lbs. ;)
/ farming with JD2210 #2
Looks like it pulled it great. :thumbsup:
/ farming with JD2210 #3
Wow, they are stronger than they look!!
Yeah, I was actually surprised. Had to do some work at my Son's house where there was deeper loose dirt. It spun a little more but still pulled it fine. :)
/ farming with JD2210 #6
I knew they had the power ,but was surprised when I seen your photo.
5-6 yrs ago one the women in neighbor tried to back her Caravan down the driveway..Well she missed her driveway with about 70-80% of her van.
Back passenger wheel completely off the ground and front passenger wheel just skimming the ground Needless to say drive is about a 40 % slope. Hooked on her van with my 2210 ,at first almost stalled.. Then I put the rpm to about 2500 her grandson 25 or so, he gave it some gas and up over the hill ..
I was impressed the way you had to be.. and yes I was in low range..
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
HEIL AIR CONDITION PACKAGE UNIT (A64281)
HEIL AIR CONDITION...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
Deere 333E (A60462)
Deere 333E (A60462)
