Farmer crushed by machine when dog moves control
   / Farmer crushed by machine when dog moves control #31
A friend was over and we spent the good part of the day moving equipment around. A couple of times I did dash under a raised loader. Just how fast will a loader come down if a line breaks? It can't be that quick.
Common sense would tell you that your taking a risk. What do you suppose could fail in that situation, that would cause the loader to drop? BTW i've done the same.
   / Farmer crushed by machine when dog moves control #32
Just saying that it typically is not one thing going wrong at a time that kills you. It is the freak thing that two bad things happen at the same time. Good safety practices generally eliminate the one thing... the other is out of your control.
Oh sure, this kind of thinking will make you old. In time.
If you've worked in dangerous environments, this kind of thinking is what gets you to the end of the day.
   / Farmer crushed by machine when dog moves control #33
My point was missed. Not that there are two cylinders. But two ports to the cylinder. When stopped, they must both be dead headed. So if you blow one, presumably the one that has pressure, the suction side will still slow the loader if it doesn't stop it completely.
   / Farmer crushed by machine when dog moves control #34
I’m pretty sure it will just pull a vacuum on the suction side.
   / Farmer crushed by machine when dog moves control #35
It would be interesting to know for sure.
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A55852)
2007 Ford F-550...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
