Farmall Super A not charging
   / Farmall Super A not charging #11
Ok that makes sense so here is my take. The battery is bad AND the Alt is not getting enough voltage for the exciter coil to kick on OR not wired correctly for the exciter coil to excite the alt to charge. Sometimes the alt needs a blip of the throttle to spin fast enough to excite. Those old tractors spin slow at idle and the smaller pulley on the alt needs a some RPM to start charging.
Clint S, this makes since to me also. The battery is very low. I will either charge the bat or pick up anther. Will let you know what happens. Thanks for your help.
   / Farmall Super A not charging #13
When looking at the back of your alt, you should have a nut with a wire that goes to your battery.
Above that, two pin connector, the first one on the left is the exciter wire, the one on the right is the wire that monitors the battery voltage and charges accordingly, this wire can be sent to the battery wire with the nut. I noticed your "two" wires pass behind your muffler, things get pretty hot there, make sure your wires are in good shape.
I will check these for any damage due to heat. Thanks
Charged the bat and tractor continued running after removing jumper cables. Thanks to all for your help and in site.
Clint S, Skyhook, Dave M7040
   / Farmall Super A not charging #16
Still check for charging, it will run quite a while on a full battery charge.
Lot (3) HD 12' Corral Panels (A50515)
Lot (3) HD 12'...
2023 KUBOTA SVL97-2 SKID STEER (A51242)
2023 KUBOTA...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
2008 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2008 CATERPILLAR...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
Deere 304K (A50120)
Deere 304K (A50120)
