Farmall Super A not charging
   / Farmall Super A not charging #11
Ok that makes sense so here is my take. The battery is bad AND the Alt is not getting enough voltage for the exciter coil to kick on OR not wired correctly for the exciter coil to excite the alt to charge. Sometimes the alt needs a blip of the throttle to spin fast enough to excite. Those old tractors spin slow at idle and the smaller pulley on the alt needs a some RPM to start charging.
Clint S, this makes since to me also. The battery is very low. I will either charge the bat or pick up anther. Will let you know what happens. Thanks for your help.
   / Farmall Super A not charging #13
When looking at the back of your alt, you should have a nut with a wire that goes to your battery.
Above that, two pin connector, the first one on the left is the exciter wire, the one on the right is the wire that monitors the battery voltage and charges accordingly, this wire can be sent to the battery wire with the nut. I noticed your "two" wires pass behind your muffler, things get pretty hot there, make sure your wires are in good shape.
I will check these for any damage due to heat. Thanks
Charged the bat and tractor continued running after removing jumper cables. Thanks to all for your help and in site.
Clint S, Skyhook, Dave M7040
   / Farmall Super A not charging #16
Still check for charging, it will run quite a while on a full battery charge.
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2015 DODGE RAM...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
