Farmall Super A hydralic pump smoking
   / Farmall Super A hydralic pump smoking #1
hinghamjd
Hingham, MA
JD 3320, 1947 Farmall Super A
I had to split the tractor to do a freeze plug, so I had to drain the hydro oil. Now that the tractor is back together I filled the hydro reservoir, but the oil is not getting to the pump, is there a way to bleed the lines going to the pump. Thanks
   / Farmall Super A hydralic pump smoking #2
You might need a little air in th ehyd tank to help the flow About 5 lbs of air .
thanks JJ, I'll give that a try
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
Landoll Hauloll (A53472)
Landoll Hauloll...
Electric Mobility Scooter (A51694)
Electric Mobility...
JOHN DEERE 4730 LOT IDENTIFIER 261 (A53084)
JOHN DEERE 4730...
