Farmall Super A carburetor
   / Farmall Super A carburetor #1
shajoe44
North Augusta, SC
Kubota MX5000
I just inherited a 4 cylinder Super A tractor. I can get it to run by spraying starter fluid in the air intake side of the carburetor. I am not getting a good flow out the bottom of the carburetor so I am sure it is stopped up inside. I was wondering where is the best place to purchase a carburetor for this tractor. I have seen them listed online from $50 all the way up to $300. Thanks
   / Farmall Super A carburetor #2
Before buying another carb., remove the elbow where the fuel line attaches to the carb. There should be a strainer on the other end. Sounds like it'splugged. Remove, and backflush with spray carb.cleaner. Re-install,and check for fuel flow.
   / Farmall Super A carburetor #3
That and a rebuild kit should be enough if just that doesn't work... It's a simple carb, some carb cleaner, a tooth brush (probably not necessary) and a piece of wire along with the rebuild kit (likely just the gasket and a float needle) and you should be good to go. I've made a gasket out of a cereal box for similar and that worked fine...
Thanks, I will look at that
HYSTER 50 FORKLIFT (A52472)
HYSTER 50 FORKLIFT...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
DOOSAN G70 PORTABLE GENERATOR (A52472)
DOOSAN G70...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52748)
2011 New Holland...
