Farmall M Engine Knocking
/ Farmall M Engine Knocking
Changed everything out and it is running fine. Thanks everyone for your help.
/ Farmall M Engine Knocking #12
Hmmmm..., Re-read the last line... *There is also some oil blow by coming out of the air filter. Anyone have any suggestions?*
If there is oil blow by out of the air filter, sounds like a problem with the intake valve. Broken/weak valve spring..?? Valve sticking, or bent..?? I'd be pulling the valve cover before running any longer, before it possibly sucks a valve..!! Better safe, than sorry...!!
/ Farmall M Engine Knocking #13
It still could be something with the timing. Fireing when the intake valve is open causing the oil. It was never said if the oil stoped coming out after the wires and stuff were changed.
/ Farmall M Engine Knocking #14
compression test time.. and fire order check!
/ Farmall M Engine Knocking #16
any details as to what you found?
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2014 Dodge Grand Caravan Van (A59231)
2014 Dodge Grand...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
BOX BLADE (A58214)
BOX BLADE (A58214)
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
