Farmall Cub
   / Farmall Cub #1
Ortis
Maryland
I have a Cub from the '70s I suppose since it has the squared off hood fron rather than the better looking (I believe) rounded one. It came with a 5' belly mower. i mowed with it for a while, but found that it had too little power to work on moderately thick, high grass or up hills, except in first gear. Now I just keep a blade on the front and use it for pushing hings around and pulling a cart.
Is my experience unique, or is it the norm for Cubs? I know it has only ~14 HP, so why do people like and seek out Cubs?
Regards
Ortis
   / Farmall Cub #2
Check out the Farmall Cub board here. Lots of Cub fans, with plenty of information and ideas. I have a '64 Lo-Boy. I still use it to rough mow paths in the woods. I have a smaller deck and the Cub does a good job.
   / Farmall Cub #3
</font><font color="blue" class="small">( i mowed with it for a while, but found that it had too little power to work on moderately thick, high grass or up hills, except in first gear. )</font>
I had a Cub several years ago and had the same experience. If the grass was 6" tall or I was going up hill: 1st gear had to be used. I always thought the Farmall Super A would be nice. About the same size as a Cub but with much more HP.
   / Farmall Cub #4
</font><font color="blue" class="small">( so why do people like and seek out Cubs? )</font>
Because they are easy to work on and get parts for. Plus they can take abuse.
-Mike Z. /forums/images/graemlins/grin.gif
   / Farmall Cub #5
I have a 66 IH cub.. and it has a 4' IH belly mower. That's all it wants to pull as well. IMHO.. a 5' rotary mower is way too much load.. look at what size tractors are pulling 5' mowers.. 20 hp or so.. etc. If you had a sickle bar mower.. it would pull 5' fine.
Soundguy
   / Farmall Cub #6
Ortis, My wife's tractor is her Grandpa's 1947 Farmall A (18HP). It has a 4ft belly mower that works great for mowing walking and golf cart trails. I also put a the trailer behind it for people transportation. Here it is pictured with the now famous Eddie Walker's girlfriend's son.
   / Farmall Cub #7
they are little enough to go in the garage and they are kinda cute /forums/images/graemlins/smile.gif
Ben
   / Farmall Cub #8
Some things you might try are to get the front of the mower a little lower than the rear so the blades are only cutting once.
Also, if it bogs down grab a lower gear and or only limit the cut to a 1/2 swath.
Cub in action
Tbar
   / Farmall Cub #9
A Cub has only 14 hp or so - but that's at 1600 rpm. That means it has the crankshaft torque of a 'modern' garden tractor of around 32 hp that's rated at 3600 rpm. (say 44-46 lb-ft).
There are some amazing pictures of Cubs in action in the book "Farmall Cub Photo Archive".
Don't believe anyone who insists the Japanese invented the compact tractor, unless they're using a very narrow definition.
UNUSED JCT DUSTLESS BLASTER (A51244)
UNUSED JCT...
E-Z TRENCH GROUND SAW (A51244)
E-Z TRENCH GROUND...
Bush Hog 2615 Batwing Mower (A50514)
Bush Hog 2615...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
BANDIT 4680 MOBILE GRINDER (A51242)
BANDIT 4680 MOBILE...
